Hello, after updating to version v1.8.8, on my panel Nginx appears as stopped, but via ssh the service is running.
- Hestia Control Panel v1.8.8
- Operating SystemDebian 10.13 (x86_64)
Well, seems Debian buster doesn’t support option -d
for pidof
pidof(8) — sysvinit-utils — Debian buster — Debian Manpages
I’ll take a look into it.
Edit: I’ve created a PR so it will work again in Debian Buster
If you want to fix the issue, now:
Create a backup of /usr/local/hestia/bin/v-list-sys-services
and once done, edit the file:
In line 90 change this:
pids=$(pidof -d '|' $name)
by this:
pids=$(pidof $name | tr ' ' '|')
In line 92 change this:
pids=$(pidof -d '|' -x $name)
by this:
pids=$(pidof -x $name | tr ' ' '|')
And check again nginx service in Web UI.
@sahsanu It worked perfectly, thank you very much!
