Nginx Laravel template causes 404 on images
I am running invoice ninja with the default laravel template and nginx. I found that everything works except when uploading images. Images upload but on preview it is 404 in error console.
If i edit the nginx conf and remove this png/jpg/jpeg it loads fine.
location / {
		expires 30d;
Is this intentional from hestia side?
Hi Elmo,
Do you already fixed the issue?
Normally Laravel will handle this when you put the images in the public folder.
But i don’t know about invoice ninja.
Yes i fixed it by editing out jpg/jpeg/png from the above code. I had to create a custom template. I do not know the purpose for that code block hopefully its not a security problem
that code block is for caching so it is no security issue but it can slow down the page speed and increases your data traffic.
hmm but why would it cause pictures not to work. It becomes http 404 error with that block.
Can you show more of the nginx config?
Default Web Domain Template
DO NOT MODIFY THIS FILE! CHANGES WILL BE LOST WHEN REBUILDING DOMAINS
Web Templates and FastCGI/Proxy Cache | Hestia Control Panel
server {
listen %ip%:%web_ssl_port% ssl;
root %sdocroot%/public;
access_log /var/log/nginx/domains/%domain%.log combined;
access_log /var/log/nginx/domains/%domain%.bytes bytes;
error_log /var/log/nginx/domains/%domain%.error.log error;
gzip on;
gzip_types application/javascript application/x-javascript text/javascript text/plain application/xml application/json;
gzip_proxied    no-cache no-store private expired auth;
gzip_min_length 1000;
ssl_stapling        on;
ssl_stapling_verify on;
# TLS 1.3 0-RTT anti-replay
location = /favicon.ico {
	log_not_found off;
	access_log off;
location = /robots.txt {
	allow all;
	log_not_found off;
	access_log off;
	deny all;
	return 404;
location / {
	location ~* ^.+\.(ogg|ogv|svg|svgz|swf|eot|otf|woff|woff2|mov|mp3|mp4|webm|flv|ttf|rss|atom|gif|webp|ico|bmp|mid|midi|wav|rtf|css|js|jar)$ {
		expires 30d;
	location ~ [^/]\.php(/|$) {
		try_files $uri =404;
		fastcgi_index index.php;
		fastcgi_pass %backend_lsnr%;
location /error/ {
location /vstats/ {
proxy_hide_header Upgrade;
Only thing i did was remove jpg/jpeg/png and the pictures worked right after that
Thank you @eris and @elmo !
Can you change:
location / {
			expires 30d;
To this:
			expires 30d;
location / {
And test it?
