Nginx Proxy Template
Hi, I have several servers and I’m using nginx from Hestia for them. I have only one public IP address.
The problem is I’m having issues with UISP and several other servers with WebSockets; the web pages aren’t loading the WebSockets.
Are you using Nginx or Nginx+Apache2?
Which template are you using?
Show the current configuration for your domain (replace YourUser and YourDomain with the actual data):
cat /home/YourUser/conf/web/YourDomain/nginx.conf
cat /home/YourUser/conf/web/YourDomain/nginx.ssl.conf
I created 2 templates
/usr/local/hestia/data/templates/web/nginx/
proxy_ws.tpl
proxy_ws.stpl
proxy config
Previously, for my other server, I used Nginx Proxy Manager, but with HestiaCP I can have both at the same time.
ok, show me the templates
# UISP_TechMatik Reverse Proxy SSL Template
server {
listen      %ip%:%proxy_ssl_port% ssl;
error_log   /var/log/%web_system%/domains/%domain%.error.log error;
ssl_stapling        on;
ssl_stapling_verify on;
# TLS 1.3 0-RTT anti-replay
# Bloquer fichiers cachés
    deny all;
    return 404;
# Proxy principal vers UISP_TechMatik HTTP interne
location / {
    proxy_pass https://10.0.0.22:443;
    proxy_set_header Host $host;
    proxy_http_version 1.1;
    proxy_set_header Upgrade $http_upgrade;
    proxy_set_header Connection "upgrade";
    # Fichiers statiques
    location ~* ^.+\.(css|js|png|jpg|jpeg|gif|ico|svg|woff2?)$ {
        try_files $uri @fallback;
        root       %sdocroot%;
        expires    max;
# Fallback vers UISP_TechMatik
location @fallback {
# Pages d'erreur personnalisées
location /error/ {
proxy_hide_header Upgrade;
# Inclusion de configurations SSL supplémentaires
The first thing you should do is remove this line from your templates and rebuild your site:
I would use a template like this:
server {
        deny all;
        return 404;
        root       %sdocroot%;
        expires    max;
    location / {
        proxy_read_timeout 86400s;
        proxy_send_timeout 86400s;
        proxy_buffering off;
    location /error/ {
merci :slight_smile:
Thanks, it works :slight_smile:
