Yes I would; nginx.conf, nginx.forcessl.conf and nginx.conf_redirect
nginx.conf:
# Default Web Domain Template #
# DO NOT MODIFY THIS FILE! CHANGES WILL BE LOST WHEN REBUILDING DOMAINS #
# https://hestiacp.com/docs/server-administration/web-templates.html #
server {
listen 10.0.0.177:80;
server_name cooldomain.com www.cooldomain.com;
root /home/cooldomain.com/web/cooldomain.com/public_html;
access_log /var/log/nginx/domains/cooldomain.com.log combined;
access_log /var/log/nginx/domains/cooldomain.com.bytes bytes;
error_log /var/log/nginx/domains/cooldomain.com.error.log error;
include /home/cooldomain.com/conf/web/cooldomain.com/nginx.forcessl.conf*;
location = /favicon.ico {
log_not_found off;
access_log off;
location = /robots.txt {
log_not_found off;
access_log off;
deny all;
return 404;
location / {
expires 30d;
location ~* /(?:uploads|files)/.*.php$ {
deny all;
return 404;
location ~ [^/]\.php(/|$) {
try_files $uri =404;
fastcgi_index index.php;
fastcgi_pass unix:/run/php/php8.2-fpm-cooldomain.com.sock;
include /home/cooldomain.com/conf/web/cooldomain.com/nginx.fastcgi_cache.conf*;
if ($request_uri ~* "/wp-admin/|/wp-json/|wp-.*.php|xmlrpc.php|index.php|/store.*|/cart.*|/my-account.*|/checkout.*") {
set $no_cache 1;
if ($http_cookie ~* "comment_author|wordpress_[a-f0-9]+|wp-postpass|wordpress_no_cache|wordpress_logged_in|woocommerce_items_in_cart|woocommerce_cart_hash|PHPSESSID") {
set $no_cache 1;
location /error/ {
alias /home/cooldomain.com/web/cooldomain.com/document_errors/;
location /vstats/ {
alias /home/cooldomain.com/web/cooldomain.com/stats/;
include /home/cooldomain.com/web/cooldomain.com/stats/auth.conf*;
include /home/cooldomain.com/conf/web/cooldomain.com/nginx.conf_*;
nginx.forcessl.conf:
return 301 https://$host$request_uri;
nginx.conf_redirect:
if ($host != "www.cooldomain.com") {
return 301 $scheme://www.cooldomain.com $request_uri;
All looks good, could you please show how are you testing it?
When surfing the sites via http:// on a browser you are prompt to download the page, if you test it via curl you get:
curl: (1) Received HTTP/0.9 when not allowed
Too late here, I’ll take a look in the morning.
Could you confirm whether your actual domain is hp.loxxxxxxxxxxxxxgn.com?
I’ll send you via DM a different domain that you can test
Just for the records.
The problem was that @Ade removed http2 from listen heretheip:80 http2; directive in the template but didn’t rebuild the domain to apply the changes.
