I’m new to Hestiacp, I’m asking a lot of questions, as I install my applications I have doubts.
I’m installing reactjs + react router (route management), in my localhost I have an nginx with this content and it works perfectly.
server {
client_max_body_size 100M;
listen 80;
index index.html;
error_log /var/log/nginx/error.log;
access_log /var/log/nginx/access.log;
root /var/www/html;
location / {
try_files $uri $uri/ /index.html;
gzip_static on;
I try to replicate it in Hestiacp but I don’t have a template, so I make a copy of default.tpl and stpl to create a new template to use reactjs, the problem is that it is not working as it should.
This is the content of my new template react.tpl/stpl
server {
listen %ip%:%web_port%;
root %docroot%;
index index.html index.htm;
access_log /var/log/nginx/domains/%domain%.log combined;
access_log /var/log/nginx/domains/%domain%.bytes bytes;
error_log /var/log/nginx/domains/%domain%.error.log error;
location / {
location /error/ {
location ~* "/\.(htaccess|htpasswd)$" {
deny all;
return 404;
location /vstats/ {
alias %home%/%user%/web/%domain%/stats/;
I leave a video recording to see the error.
