Nginx restart failed
After an upgrade i get nginx restart failed
nginx: [warn] the “listen … http2” directive is deprecated, use the “http2” directive instead in /etc/nginx/conf.d/domains/absstem.live.ssl.conf:8
been trying to fix this by updating but all my websites are down and when i try to login it just redirects back to the login page.
At this point not sure whats going on. Please help.
What version of the panel do you have?
v-list-sys-info
   OS      VER    ARCH    HESTIA  RELEASE  UPTIME  LA
Ubuntu 20.04 x86_64 1.9.3 release 5267 0.07 / 0.02
Ubuntu 20 is not supported. Upgrade to ubuntu 22
Also consider the recommendations - Operating system upgrades | Hestia Control Panel
Ubuntu 20.04 is still supported
What is the nginx version >
nginx -v in command line
It looks like you have an outdate template it is an custom one?
nginx version: nginx/1.27.4
