this morning i found my sites down , so when i inestigate i see that apache2 webserver is dead and won’t to restart so i did this command:
sudo apt-get purge apache2
sudo apt-get install apache2
then i found also that Nginx reverse proxy won’t restart , so i did the same command for nginx but still not working
please any help and tell me how can i reinstall hestia cp without loosing my data ?
still cannot understand how to do it , please be patient with me and tell me step by step what should i do , like :
step 1 connect to ssh
Step 2 write the command …
line 2 removes the configuration file.
line 3 copies the configuration file back to the apache2 directory
I have the same problem when I checked the server after the update, off line nginx not running, all i ever do is restore a backup and try again (sometimes works with no issues, kinda temperamental).
I always check if the servers up after updates…
I host from home my own websites so its not like I have clients websites on this server
apache2 was working on mine but I can not start nginx still after upgrading again…
i think that the remove of the configuration file will not solve the problem
so i have downloaded the Backup file then reinstalled the hole vps and hestiacp then i restored the backup file via ssh command.
the server was runing well , don’t know how this problem came.
