Surjo
1
Hello, please help me, i want edit nginx default for my custom php script & WHMCS but i can’t found single domain configure like on vestacp
nano /home/user/conf/web/website1.nginx.conf
nano /home/user/conf/web/website1.nginx.ssl.conf
nano /home/user/conf/web/website2.nginx.conf
nano /home/user/conf/web/website2.nginx.ssl.conf
please help me
Dennis
2
Surjo,
you can find the templates in /usr/local/hestia/data/templates/web/nginx
Instead of editing the default template, you can copy the default templates and create 2 new files in the same folder. For example
whmcs.tpl and whmcs.stpl (they are both needed, one is for http and one is for https)
-Dennis
eris
3
You should never update any generated config files these will get overwritten during update / upgrade of Hestia
Surjo
4
Thank you soo much to all
