Nginx template for redirecting users to HestiaCP dashboard
I am trying to redirect my clients to HestiaCP using the subdomain panel.clientdomain.tld.
Details:
  • I am using port 2083 for the dashboard and have added a tpl and stpl.
  • I added an alias to the domain as panel.domain.tld and issued a Let’s Encrypt certificate without any issues.
  • I added an A record pointing panel.clientdomain.tld to the server IP.
  • The result is a bad certificate domain error because the certificate is pointing to the domain of my server, and the installed certificate is for hostname.mydomain.tld.
Error in Firefox:
Websites prove their identity via certificates. Firefox does not trust this site because it uses a certificate that is not valid for panel.clientdomain.tld:2083. The certificate is only valid for my.server.tld.
/usr/local/hestia/data/templates/web/nginx/default-redirect-cli2083.stpl
Summary
server {
    listen      %ip%:%proxy_ssl_port% ssl;
    error_log   /var/log/%web_system%/domains/%domain%.error.log error;
    ssl_stapling        on;
    ssl_stapling_verify on;
    # TLS 1.3 0-RTT anti-replay
    location / {
        if ($host = 'panel.%domain%') {
            proxy_pass https://%ip%:2083;
        } else {
        location ~* ^.+\.(%proxy_extensions%)$ {
            try_files $uri @fallback;
            root %sdocroot%;
            expires max;
    location @fallback {
        deny all;
        return 404;
    location /error/ {
    proxy_hide_header Upgrade;
/usr/local/hestia/data/templates/web/nginx/default-redirect-cli2083.tpl
Summary
server {
		deny all;
		return 404;
	location / {
			return 301 https://$host:2083$request_uri;
		proxy_pass http://%ip%:%web_port%;
			root       %docroot%;
			expires    max;
	location /error/ {
Is there another approach achieve this?
Thanks for the help :slightly_smiling_face:
if ($host = ‘panel.%domain%’) {
You should return
return 301 https://panel.%domain% instead
Take a look at:
And replace 8083 with 2083 this will remove always the :xxx requirement …
Hey @eris, I get the idea, but I’m still stuck.
I’m trying to use panel.domain.com as a way for customers to access their control panel instead of domain.com.
I changed the port in your template to 2083, but I’m running into two problems:
  1. When customers go to domain.com, it redirects them to domain.com/login, so they can’t see their webpage.
  2. panel.domain.com redirects correctly to panel.domain.com/login, but there’s a certificate issue. The browser picks up the certificate from the server where Hestia is installed, not the one that includes ‘panel.domain.com’.
I tried tweaking the templates, but no luck so far :smiling_face_with_tear:
Yes because by default hestia is hostname.com:8083
Two things: You have 2 options:
  1. Create in each user account pannel.domain.com and assign the cp.tpl to it. It should work fine
  2. Or redirect to hostname.com:2083
