I tried to add language to IPS forum hosted on hestiacp, but (nginx proxy?) throw me “timeout”
[proxy_fcgi:error] [pid 27709] (70007)The timeout specified has expired
How its can be fixed?
Hello Daffyy,
I guess you have hestia installed with : Nginx, Apache2, Multi-php
If so create a optional include file ex: /home/USERNAME/conf/web/DOMAIN.TLD/apache2.conf_fcgi
with:
# FcgidIdleTimeout 600
# FcgidProcessLifeTime 600
# FcgidConnectTimeout 600
# FcgidIOTimeout 600
# Timeout 600
ProxyTimeout 600
Only “ProxyTimeout” should be required but you can test/uncomment the other options too if still doesn’t work
Looong reply from server, but again timeout with all uncommented options form ur post
web template (apache2) is php7.3
Language to IPS = Uploading xml file and app insert it into database / cache
@edit, domain is behind cloudflare, maybe cloudflare closing long connections, but on others www hosts uploading / processing language = fast, on hestiacp = slow and error
Does anyone know how to solve the problem?
If no one reply, the unlucky answer is: no :(.
Its problem in apache2 fcgi or nginx proxy? Or something more?
Solved
/etc/apache2/mods-enabled/fcgid.conf
FcgidIOTimeout 600
ProxyTimeout 600
On my server its working if set globally, if in user apache2.conf_fcgi not
