Ngix and ssh not working please help
Hi I upgraded my VM and hestia. after that I cannot access the SSH and NGix server is off. Websites and emails are not working. Uploaded files do not appear on the server. And There’s also unknown error.
Login with console / ipmi / what ever you have
systemctl status ssh
systemctl status Nginx
Im using putty and I cannot access the vm
I managed to log in. This is what I got
results for NGIX
root@hcp:~# systemctl status Nginx
Unit Nginx.service could not be found.
root@hcp:~#
Try:
systemctl status nginx
Apache2 listens also on port 80 / 443 revert the config back before you did the update
same for ssh, never overwrite any configs…
Hi Kindly provide me with default ports for Ngix and apache because I think that I have messed up the ports.
check the referenced post above, will include all informations and configs.
Everything works but I get this error from my sites
check your logs, why you get a 500
2023/07/02 08:35:55 [error] 1108#1108: *302 SSL_do_handshake() failed (SSL: error:0A00010B:SSL routines::wrong version number) while SSL handshaking to upstream, client: 197.185.98.246, server: jats-mtis.co.za, request: “GET / HTTP/2.0”, upstream: “https://10.5.0.4:8443/”, host: “jats-mtis.co.za”
2023/07/02 08:35:56 [error] 1108#1108: *302 SSL_do_handshake() failed (SSL: error:0A00010B:SSL routines::wrong version number) while SSL handshaking to upstream, client: 197.185.98.246, server: jats-mtis.co.za, request: “GET /favicon.ico HTTP/2.0”, upstream: “https://10.5.0.4:8443/favicon.ico”, host: “jats-mtis.co.za”, referrer: “https://jats-mtis.co.za/
2023/07/02 08:36:01 [error] 1108#1108: *306 SSL_do_handshake() failed (SSL: error:0A00010B:SSL routines::wrong version number) while SSL handshaking to upstream, client: 41.160.35.134, server: jats-mtis.co.za, request: “GET / HTTP/1.1”, upstream: “https://10.5.0.4:8443/”, host: “jats-mtis.co.za”
2023/07/02 08:41:29 [error] 1108#1108: *318 SSL_do_handshake() failed (SSL: error:0A00010B:SSL routines::wrong version number) while SSL handshaking to upstream, client: 154.16.95.42, server: jats-mtis.co.za, request: “GET / HTTP/2.0”, upstream: “https://10.5.0.4:8443/”, host: “jats-mtis.co.za”
2023/07/02 08:41:29 [error] 1108#1108: *318 SSL_do_handshake() failed (SSL: error:0A00010B:SSL routines::wrong version number) while SSL handshaking to upstream, client: 154.16.95.42, server: jats-mtis.co.za, request: “GET /favicon.ico HTTP/2.0”, upstream: “https://10.5.0.4:8443/favicon.ico”, host: “jats-mtis.co.za”, referrer: “https://jats-mtis.co.za/
2023/07/02 08:45:41 [error] 1108#1108: *334 SSL_do_handshake() failed (SSL: error:0A00010B:SSL routines::wrong version number) while SSL handshaking to upstream, client: 197.185.98.246, server: jats-mtis.co.za, request: “GET / HTTP/2.0”, upstream: “https://10.5.0.4:8443/”, host: “jats-mtis.co.za”
2023/07/02 08:45:42 [error] 1108#1108: *334 SSL_do_handshake() failed (SSL: error:0A00010B:SSL routines::wrong version number) while SSL handshaking to upstream, client: 197.185.98.246, server: jats-mtis.co.za, request: “GET /favicon.ico HTTP/2.0”, upstream: “https://10.5.0.4:8443/favicon.ico”, host: “jats-mtis.co.za”, referrer: “https://jats-mtis.co.za/
2023/07/02 09:41:33 [error] 1108#1108: *464 SSL_do_handshake() failed (SSL: error:0A00010B:SSL routines::wrong version number) while SSL handshaking to upstream, client: 157.55.39.223, server: jats-mtis.co.za, request: “GET /robots.txt HTTP/2.0”, upstream: “https://10.5.0.4:8443/robots.txt”, host: “jats-mtis.co.za”
2023/07/02 10:07:09 [error] 1146#1146: *14 SSL_do_handshake() failed (SSL: error:0A00010B:SSL routines::wrong version number) while SSL handshaking to upstream, client: 223.111.175.25, server: jats-mtis.co.za, request: “GET / HTTP/1.1”, upstream: “https://10.5.0.4:8443/”, host: “www.jats-mtis.co.za”
2023/07/02 10:07:28 [error] 1146#1146: *35 SSL_do_handshake() failed (SSL: error:0A00010B:SSL routines::wrong version number) while SSL handshaking to upstream, client: 41.114.17.134, server: jats-mtis.co.za, request: “GET / HTTP/2.0”, upstream: “https://10.5.0.4:8443/”, host: “jats-mtis.co.za”
2023/07/02 10:07:29 [error] 1146#1146: *35 SSL_do_handshake() failed (SSL: error:0A00010B:SSL routines::wrong version number) while SSL handshaking to upstream, client: 41.114.17.134, server: jats-mtis.co.za, request: “GET /favicon.ico HTTP/2.0”, upstream: “https://10.5.0.4:8443/favicon.ico”, host: “jats-mtis.co.za”, referrer: “https://jats-mtis.co.za/
2023/07/02 12:18:35 [error] 1146#1146: *305 SSL_do_handshake() failed (SSL: error:0A00010B:SSL routines::wrong version number) while SSL handshaking to upstream, client: 41.114.15.2, server: jats-mtis.co.za, request: “GET / HTTP/2.0”, upstream: “https://10.5.0.4:8443/”, host: “jats-mtis.co.za”
2023/07/02 12:18:36 [error] 1146#1146: *305 SSL_do_handshake() failed (SSL: error:0A00010B:SSL routines::wrong version number) while SSL handshaking to upstream, client: 41.114.15.2, server: jats-mtis.co.za, request: “GET /favicon.ico HTTP/2.0”, upstream: “https://10.5.0.4:8443/favicon.ico”, host: “jats-mtis.co.za”, referrer: “https://jats-mtis.co.za/
2023/07/02 12:37:31 [error] 1146#1146: *381 SSL_do_handshake() failed (SSL: error:0A00010B:SSL routines::wrong version number) while SSL handshaking to upstream, client: 197.185.100.23, server: jats-mtis.co.za, request: “GET / HTTP/2.0”, upstream: “https://10.5.0.4:8443/”, host
This is where I got the error log. Is this the right place?
