i have the same error, but non of above worked for me
~ # apt-get install libzip5 && systemctl restart hestia
Reading package lists… Done
Building dependency tree
Reading state information… Done
Package libzip5 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package ‘libzip5’ has no installation candidate
~ # apt-get install libzip4 && systemctl restart hestia
libzip4 is already the newest version (1.5.1-4+0~20190318173200.9+buster~1.gbp333132).
libzip4 set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
systemctl status hestia
Active: active (running) since Sun 2020-07-19 21:14:57 BST; 4min 45s ago
Process: 5769 ExecStart=/etc/init.d/hestia start (code=exited, status=0/SUCCESS)
Tasks: 3 (limit: 4915)
Memory: 11.9M
CGroup: /system.slice/hestia.service
├─5775 nginx: master process /usr/local/hestia/nginx/sbin/hestia-nginx
├─5776 nginx: worker process
└─5778 php-fpm: master process (/usr/local/hestia/php/etc/php-fpm.conf)
Jul 19 21:15:14 server.lislehost.com sudo[6118]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jul 19 21:15:14 server.lislehost.com sudo[6118]: pam_unix(sudo:session): session closed for user root
Jul 19 21:15:14 server.lislehost.com sudo[6124]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jul 19 21:15:14 server.lislehost.com sudo[6124]: pam_unix(sudo:session): session closed for user root
Jul 19 21:15:16 server.lislehost.com sudo[6146]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jul 19 21:15:16 server.lislehost.com sudo[6146]: pam_unix(sudo:session): session closed for user root
Jul 19 21:15:16 server.lislehost.com sudo[6149]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jul 19 21:15:16 server.lislehost.com sudo[6149]: pam_unix(sudo:session): session closed for user root
Jul 19 21:15:16 server.lislehost.com sudo[6155]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jul 19 21:15:16 server.lislehost.com sudo[6155]: pam_unix(sudo:session): session closed for user root
[> Sun Jul 19 21:30:08.419111 2020] [ssl:warn] [pid 1631] AH01909: 176.9.39.57:443:0 server certificate does NOT include an ID which matches the server name
It is complaining that mpm_prefork causing the issue. This issue is not related to “Hestia Nginx” package or Control panel it self. Requesting an SSL certificate for the control pannel wil not resolve the issue…
i have disabled csf and still the same, if was csf i would not be able to access server at all, but i can view sites running on server it and ssh to iti get internal error 500 when trying to view hestacp.
