ok
libicu57:amd64 57.1-6+deb9u4
libicu63:amd64 63.1-6+deb10u1
libicu65:amd64 65.1-1+0~20200223.8+debian9~1.gbp519cf3
No result
/var/log/hestia/error.log
2021-07-19 14:00:02 v-update-sys-rrd-mysql 'daily' [Error 15]
2021-07-22 03:14:12 v-update-sys-hestia 'hestia' [Error 19]
2021-07-22 03:14:17 v-update-sys-hestia 'hestia-nginx' [Error 19]
2021-07-22 03:14:21 v-update-sys-hestia 'hestia-php' [Error 19]
/var/log/hestia/nginx-error.log
2021/07/22 00:35:12 [crit] 787#0: *3 connect() to unix:/var/run/hestia-php.sock failed (2: No such file or directory) while connecting to upstream, client: 143.110.234.254, server: _, request: "GET /system_api.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/hestia-php.sock:", host: "my_ip:8083"
2021/07/22 00:35:15 [error] 787#0: *7 open() "/usr/local/hestia/web/c/version.js" failed (2: No such file or directory), client: 143.110.234.254, server: _, request: "GET /c/version.js HTTP/1.1", host: "my_ip:8083"
2021/07/22 00:35:18 [crit] 787#0: *10 connect() to unix:/var/run/hestia-php.sock failed (2: No such file or directory) while connecting to upstream, client: 143.110.234.254, server: _, request: "GET /streaming/clients_live.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/hestia-php.sock:", host: "my_ip:8083"
2021/07/22 00:35:21 [error] 787#0: *14 open() "/usr/local/hestia/web/stalker_portal/c/version.js" failed (2: No such file or directory), client: 143.110.234.254, server: _, request: "GET /stalker_portal/c/version.js HTTP/1.1", host: "my_ip:8083"
2021/07/22 00:35:25 [crit] 787#0: *17 connect() to unix:/var/run/hestia-php.sock failed (2: No such file or directory) while connecting to upstream, client: 143.110.234.254, server: _, request: "GET /stream/live.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/hestia-php.sock:", host: "my_ip:8083"
2021/07/22 00:35:28 [error] 787#0: *21 open() "/usr/local/hestia/web/flu/403.html" failed (2: No such file or directory), client: 143.110.234.254, server: _, request: "GET /flu/403.html HTTP/1.1", host: "my_ip:8083"
2021/07/22 02:40:41 [crit] 787#0: *27 connect() to unix:/var/run/hestia-php.sock failed (2: No such file or directory) while connecting to upstream, client: 167.248.133.37, server: _, request: "GET / HTTP/1.1", upstream: "fastcgi://unix:/var/run/hestia-php.sock:", host: "my_ip:8083"
2021/07/22 03:18:31 [crit] 787#0: *30 connect() to unix:/var/run/hestia-php.sock failed (2: No such file or directory) while connecting to upstream, client: 185.220.100.248, server: _, request: "GET / HTTP/1.1", upstream: "fastcgi://unix:/var/run/hestia-php.sock:", host: "my_ip:8083", referrer: "http://my_ip:8083/"
2021/07/22 13:50:20 [error] 4269#0: *3 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 167.172.42.105, server: _, request: "GET /system_api.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/hestia-php.sock:", host: "my_ip:8083"
2021/07/22 13:50:20 [error] 4269#0: *7 open() "/usr/local/hestia/web/c/version.js" failed (2: No such file or directory), client: 167.172.42.105, server: _, request: "GET /c/version.js HTTP/1.1", host: "my_ip:8083"
2021/07/22 13:50:21 [error] 4269#0: *10 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 167.172.42.105, server: _, request: "GET /streaming/clients_live.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/hestia-php.sock:", host: "my_ip:8083"
2021/07/22 13:50:21 [error] 4269#0: *14 open() "/usr/local/hestia/web/stalker_portal/c/version.js" failed (2: No such file or directory), client: 167.172.42.105, server: _, request: "GET /stalker_portal/c/version.js HTTP/1.1", host: "my_ip:8083"
2021/07/22 13:50:21 [error] 4269#0: *17 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 167.172.42.105, server: _, request: "GET /stream/live.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/hestia-php.sock:", host: "my_ip:8083"
My Hestia worked perfectly for about a year on auto-update, and when updating to 1.4.7, there is no possibility to go to the admin panel, the problem with auto-update and Debian 10? Team, ideas solution, fix, something?
