No have no found "Proxy Template"
No found exist
where is proxy template???
Exist google search:
You don’t have apache2 installed
Wait, where is install apache2? but think yes have apache2 and nginx.
It is currently reinstall server completely and enable it by setup
Or follow the installer steps 1 by 1 and do it that way
I understood but I will see a solution, thanks.
Oh but nginx can :8083 use subdomain panel.example.com?
Yes you can use:
and
Copy them into:
/usr/local/hestia/data/templates/web/nginx/php-fpm/
Thanks you working and question last final:
Like if I remove firewall and that :8083 is removed and I can that work panel.example.com and I no longer need example.com:8083?
After you saved it should work fine
Sorry problem my banned message “spam” haha - Thanks done solution closed post!
Excellent help eris
