Hello, I’ve not see nginx Template to Change template when login as User.
But when Login as Admin i have able to Change nginX Template…
Login As User –
Login as Admin –
Please help me
Login As User –
Login as Admin –
Please help me
Its already set as Yes
but not work,
i’ve try to set No and again set Yes, but still not working…
I’ve Install 3 New Server Yesterday, all server has same problem…
Also I have no issue on my test server.
According the code it should work…
What happens when you enable Debug mode in settings and then login as that user. And then click on the yellow bar. It will drop down some debug info
