So i’m researching this issue but there doesn’t seem to be a resolution. Other posts say the error with the LetsEncrypt SSL cert in the HestiaCP is LetsEncrypt rate limiting the server/host IP.
I’m only adding one site. I tried last night it failed, tried again this morning and same error. Attempted to add the SSL both from the Hestia control panel and from the command line. Any ideas?
I think i see the issue now. DNS isn’t resolving properly. Attempted to fix it but still not working so I’m re-imaging the server. Should hopefully fix it. Thank you!
Odd, so i reimaged the server, confirmed I could ping google.com DNS was working etc. I installed HestiaCP which required me to reboot. After reboot DNS stopped working again.
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.4 LTS
Release: 22.04
Codename: jammy
added those name servers just in case, rebooted, and still no DNS. It’s odd because I’ve installed HestiaCP on numerous other Ubuntu 22 VPS servers and never had this issue. Could it be an issue with my host/the image they’re using for Ubuntu? I’m lost at this point.
It has to be something with the image they’re using. I’m going to request to have Ubuntu 20 installed and if that doesn’t work I’m moving to a new VPS provider lol…
that doesnt solve your issue, just stops the firewall until a reboot. So probaly openvz, i would suggest to change the provider. hetzner.com is a well loved alternative.
Right, that’s what I thought but I rebooted and it seems to be functioning correctly. Let’s Encrypt is working as well after reboot. Hetzner is great, I do use them for one of my hosts currently, but I’m trying to spread out my infrastructure to different hosts. I might move to AWS if I continue having issues with this host.
