Were you asked to replace the roundcube config files during upgrade? How did you installed hestia? Did you do a apt update && apt dist-upgrade before install it?
Hestia itself upgrades your system packages (apt upgrade), so there should be nothing to upgrade after install, expect kernel images.
I did rebuild the server, being clean, I did apt update & apt upgrade, later I installed Hestia as I had before with nginx without apache, I created the users that I had before and when I put webmail.domain.cl, that error appears
I’m sorry but we can’t do the debug work for you. Please check your logs, infact it’s a database connection error, check if your mariadb server is up and running, then further check the credentials in your rouncube log, if you can login to the database. Just a few ideas here.
First of all I want to apologize for my ignorance, and if I have bothered you, my lack of experience does not let me see the obvious, in addition to not understanding English, I have to use Google Translate to communicate.
The downside was that MariaDB was not working.
Apologies
Hy @ClaudioSpcSpa
You’re welcome!
Human beings are not born with knowledge!
The human being learns his wisdom, even if gradually!
But right now, the problem was solved !?
Now, whether if it was resolved or not, leave here your operating system descriptionthat you are using…
It’s important for everyone
