I have developed a plugin that can help you install applications that use NodeJS.
It works using QuickInstall App and allows different ports to be used for various NodeJS applications.
I hope it helps
I hope it helps
I tried but got internal server error after uploading my app. Any help?
Please check and provide log files, otherwise its only guessing.
Where can I get specific log files?
Working fine now. I forgot to install npm modules.
