when I try to install cloudflare origin certificate SSL it shoes error please help me to fix it.
ERROR : ssl certificate key pair is not valid
Are you sure you are using the right private key for your origin cert?
When you create an origin cert you must copy the private key (you won’t be able to save it later). Do it again copying the right cert and key to the right fields in Hestia.
I tried this 3 times.
I know I am doing in right way.
I create origin certi first and then copy both the keys from cloudflare and paste in HestiaCP SSL.
But again and again it shows same error.
And one more thing I installed HestiaCP in Debian 12 is it good to go?
I tested it right now and I had no issues to add it in Hestia:
If you are using a RSA certificate, remember to add the Cloudflare Origin CA Root Certificate to field SSL Certificate Authority / Intermediate in Hestia.
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
If you are using a ECC certificate, remember to add the Cloudflare Origin CA Root Certificate to field SSL Certificate Authority / Intermediate in Hestia.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Yes, it is.
One more thing, the origin certificate you are creating is valid for *.yourdomain.tld AND yourdomain.tld?
Also, a wildcard cert if valid only for the subdomain level it was created for, I mean, if the certificate only was issued for *.yourdomain.tld, it will be valid for www.yourdomain.tld, webmail.yourdomain.tld, etc. but it WON’T be valid neither for whatever.www.yourdomain.tld nor yourdomain.tld
What are the domains included in the certificate and what are the domain and aliases in Hestia where you are adding it?
same error.
now I reinstalled hestiacp in new VPS then also same problem.
my cloudflare encryption is on Full (strict)
and then I created new origin certificate but same error problem is there.
I followed this guy from youtube but my problem remains same : https://www.youtube.com/watch?v=BK7qyPa-VmI
error screenshot:
Could you please send to me via private message one of the certificates and the associated private key that you won’t use anymore so I can test it?
No, If you are already using Cloudflare’s dns servers, those name servers don’t matter.
