Hi
from any days the backup is stopped for a single user.
If I try to make a manual backup receive this email
not enough diskspace available to perform the backup.
Filesystem Size Used Avail Use% Mounted on
udev 966M 0 966M 0% /dev
tmpfs 196M 23M 174M 12% /run
/dev/sda1 38G 9.9G 27G 28% /
tmpfs 979M 0 979M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 979M 0 979M 0% /sys/fs/cgroup
tmpfs 196M 0 196M 0% /run/user/0
I deleted the command in /usr/local/hestia/data/queue/backup.pipe but it doesn’t solve my issue.
eris
November 6, 2020, 3:34pm
2
On what drive is “/backup/” located? On /dev/sda1/
How big is the user you want to backup?
my backup is local, not ftp. it is on /backup folder.
Normally it is about 230mb. I exclude a folder because it was 7gb
eris
November 6, 2020, 4:39pm
4
We currently check / match the account size x 2 against the available disk space. It will not surprise me there is an “issue” that the current account size is included…
How do you exclude a specific folder from the backup ?
eris
November 6, 2020, 6:35pm
6
# Validate available disk space (take usage * 2, due to the backup handling)
let u_disk=$(grep "U_DISK=" $HESTIA/data/users/$user/user.conf |cut -f 2 -d \')*2
let v_disk=$(($(stat -f --format="%a*%S" $BACKUP)))/1024/1024
if [ "$u_disk" -gt "$v_disk" ]; then
echo "not enough diskspace available to perform the backup." |$SENDMAIL -s "$subj" $email $notify
check_result $E_LIMIT "not enough diskspace available to perform the backup."
fi
We need to modify some code probally currently we measure the “needed”
Can you create an issue on Github?
I have setup in the package 7 backups.
In the panel I see only 3 backups but in the /backup folder there are 7 backups…but the last backup is done in date 02 november ( there are from 27 october to 02 november).
I think someone needs to learn how to partition, rather than use directories.
