I have hestiacp that has not been updated to v1.3.3 and has stayed at version 1.2.4
I have done apt update and apt upgrade but it remains the same, from the panel I have also gone to update and it does nothing of ada, it does not mark an error but it does not update, how can I solve this problem?
I see the problem I have and it is not in the only server that has happened to me, the package installed is actually hestia 1.3.3 but in the panel it continues to show the wrong version and in the hesta.conf it is also wrong.
What should I do? I change it from hestacp.conf or is there a way to get it to sync the panel to the correct version?
