Not work PHP code in HTML files
After the migration Centos + Vestacp on Ubuntu + Hestia does not work PHP code in HTML files. After returning to Vestacp, everything works. In the Vestacp at the “Proxy Extensions” item were deleted .htm and .html, and I add the .htacess (AddHandler application/x-httpd-php .php .htm .html) file for PHP code to work. What needs to be changed in Hestia?
We don’t use modphp you need to use fpm
Create a new template in /usr/local/hestia/data/templates/web/apache2/php-fpm/
And include in both templates:
<FilesMatch \.html$>
        SetHandler "proxy:%backend_lsnr%|fcgi://localhost"
    </FilesMatch>
In this folder I found two files - default.tpl and default.stpl. Each file starts with “VirtualHost” and ends with “/VirtualHost” . Should I remove .htaccess and add this code at the end of each file? Or I am not remove .htaccess and I must create a new tpl (forhtml.tpl) with this code ?
Create new template
html.stpl
# https://docs.hestiacp.com/admin_docs/web.html#how-do-web-templates-work #
<VirtualHost %ip%:%web_ssl_port%>
    ServerName %domain_idn%
    %alias_string%
    ServerAdmin %email%
    DocumentRoot %sdocroot%
    ScriptAlias /cgi-bin/ %home%/%user%/web/%domain%/cgi-bin/
    Alias /vstats/ %home%/%user%/web/%domain%/stats/
    Alias /error/ %home%/%user%/web/%domain%/document_errors/
    #SuexecUserGroup %user% %group%
    CustomLog /var/log/%web_system%/domains/%domain%.bytes bytes
    CustomLog /var/log/%web_system%/domains/%domain%.log combined
    ErrorLog /var/log/%web_system%/domains/%domain%.error.log
    <Directory %home%/%user%/web/%domain%/stats>
        AllowOverride All
    </Directory>
    <Directory %sdocroot%>
        AllowOverride All
        SSLRequireSSL
        Options +Includes -Indexes +ExecCGI
	</Directory>
    SSLEngine on
    SSLVerifyClient none
    SSLCertificateFile %ssl_crt%
    SSLCertificateKeyFile %ssl_key%
    %ssl_ca_str%SSLCertificateChainFile %ssl_ca%
    <FilesMatch \.php$>
    </FilesMatch>
    </FilesMatch>
    SetEnvIf Authorization .+ HTTP_AUTHORIZATION=$0
    IncludeOptional %home%/%user%/conf/web/%domain%/%web_system%.ssl.conf_*
    IncludeOptional /etc/apache2/conf.d/*.inc
</VirtualHost>
And do the same for .tpl:
<VirtualHost %ip%:%web_port%>
    %alias_string%
    ServerAdmin %email%
    DocumentRoot %docroot%
    IncludeOptional %home%/%user%/conf/web/%domain%/apache2.forcessl.conf*
        AllowOverride All
    </Directory>
        AllowOverride All
    </Directory>
    <FilesMatch \.php$>
    </FilesMatch>
    </FilesMatch>
    IncludeOptional %home%/%user%/conf/web/%domain%/%web_system%.conf_*
</VirtualHost>
And delete or at least remove the AddHandler application/x-httpd-php .php .htm .html part
Added html.stpl and html.tpl , removed .htaccess, but this unfortunately does not work, PHP is not displayed. Something else needs to be changed?
Hmmm… I change Web TemplateAPACHE2 on domain, open the “Access Denied”. Nice…
  1. When I use the Web Template APACHE2 default template, the site works, but PHP links does not display, and when I use the html template, the site is not available (503 service unavailable)
  2. If I transfer html sites to Wordpress with the .html page extension, will I need an html template?
