Hello everyone,
I have Hestia v1.3.3 installed, this morning I did an update and since then I can’t access one of three websites.
I have checked apache2 and nginx status, both running without issues.
The error I am getting is open_basedir restriction in effect:
open_basedir restriction in effect. File(/home/xtvcz/web/xtv.cz/public_html/vendor/autoload.php) is not within the allowed path(s): (/home/xtvcz/web/xtv.cz/public_html/public:/home/xtvcz/web/xtv.cz/public_shtml:/home/xtvcz/tmp:/var/www/html:/etc/phpmyadmin:/var/lib/phpmyadmin:/etc/phppgadmin:/etc/roundcube:/var/lib/roundcube:/tmp:/bin:/usr/bin:/usr/local/bin:/usr/share:/opt)
For a file that is definitely within allowed paths.
My custom (s)tpl file is configured as follows:
php_admin_value open_basedir %docroot%:%home%/%user%/tmp:/home/%user%/web/%domain%/public_html:/home/xtvcz/hddarchiv:/home/xtvdata/web/moneys.xtv.cz/public_html
Resulting configuration file in /etc/php/7.4/fpm/pool.d/xtv.cz.conf:
php_admin_value[open_basedir] = /home/xtvcz/web/xtv.cz/public_html/:/home/xtvcz/hddarchiv:/home/xtvcz/web/xtv.cz/public_shtml:/home/xtvcz/tmp:/var/www/html:/etc/phpmyadmin:/var/lib/phpmyadmin:/etc/phppgadmin:/etc/roundcube:/v>
It looks like my template file is not somehow registered by php-fpm/apache?
I have tried rebuilding domain from admin panel and rebuilding user with
v-rebuild-user xtvcz
But with no luck.
Is there any other path these template files are being compiled to?
Another thing is I have other domain dev.xtv.cz, that uses the same configuration templates, and is working correctly.
Thank you for any help.
eris
February 26, 2021, 7:51am
#2
I have updated these files:
/usr/local/hestia/data/templates/web/php-fpm/PHP-7_4.tpl
/usr/local/hestia/data/templates/web/apache2/xtvcz-PHP-7_4.stpl
Both of which are set as active in domain settings:
eris
February 26, 2021, 8:04am
#4
Web template should be the default.tpl (Unless you made other changes)
And Backend Template should be come xtvcz-PHP-7_4.tpl containing:
; origin-src: deb/php-fpm/multiphp.tpl
[%domain%]
listen = /run/php/php%backend_version%-fpm-%domain%.sock
listen.owner = %user%
listen.group = www-data
listen.mode = 0660
user = %user%
group = %user%
pm = ondemand
pm.max_children = 8
pm.max_requests = 4000
pm.process_idle_timeout = 10s
pm.status_path = /status
php_admin_value[upload_tmp_dir] = /home/%user%/tmp
php_admin_value[session.save_path] = /home/%user%/tmp
php_admin_value[open_basedir] = /xxxxxxx:/home/%user%/web/%domain%/public_html:/home/%user%/web/%domain%/private:/home/%user%/web/%domain%/public_shtml:/home/%user%/tmp:/var/www/html:/etc/phpmyadmin:/var/lib/phpmyadmin:/etc/phppgadmin:/etc/roundcube:/var/lib/roundcube:/tmp:/bin:/usr/bin:/usr/local/bin:/usr/share:/opt
php_admin_value[sendmail_path] = /usr/sbin/sendmail -t -i -f [email protected] %domain%
env[PATH] = /usr/local/bin:/usr/bin:/bin
env[TMP] = /home/%user%/tmp
env[TMPDIR] = /home/%user%/tmp
env[TEMP] = /home/%user%/tmp
It should work straight out of the box after you replaced: /xxxxxxx with the correct path
I have created the file, updated domain and rebuild user.
But the error message displays slightly different open_basedir configuration.
...is not within the allowed path(s): (/home/xtvcz/hddarchiv:/home/xtvcz/web/xtv.cz/public_html/public:/home/xtvcz/web/xtv...
My TPL config if as follows:
php_admin_value[open_basedir] = /home/xtvcz/hddarchiv:/home/%user%/web/%domain%/public_html:/home/%user%/web/%domain%/private:...
I forgot to mention I have set custom root in web settings:
I suspect this might be causing the issue because even though the open_basedir rules are being updated (according to the error message, open_basedir rule is different than before), the paths are almost the same except the added public
after
Should I add anything else in the TPL config?
eris
February 26, 2021, 8:41am
#6
If you are using an custom dir you made add the full path the open base dir
Here is how my /usr/local/hestia/data/templates/web/php-fpm/xtvcz-PHP-7_4.tpl
looks:
[%domain%]
listen.mode = 0660
user = %user%
group = %user%
pm = ondemand
pm.max_children = 8
php_admin_value[open_basedir] = /home/xtvcz/hddarchiv:/home/xtvcz/web/xtv.cz/public_html/public:/home/%user%/web/%domain%/public_html:/home/%user%/web/%domain%/public_html:/home/%user%/web/%domain%/private:/home/%user%/web/%domain%/public_shtml:/home/%user%/tmp:/var/www/html:/etc/phpmyadmin:/var/lib/phpmyadmin:/etc/phppgadmin:/etc/roundcube:/var/lib/roundcube:/tmp:/bin:/usr/bin:/usr/local/bin:/usr/share:/opt
Here is how the produced /etc/php/7.4/fpm/pool.d/xtv.cz.conf
file looks:
[xtv.cz]
listen = /run/php/php7.4-fpm-xtv.cz.sock
listen.owner = xtvcz
listen.mode = 0660
user = xtvcz
group = xtvcz
pm = ondemand
pm.max_children = 8
php_admin_value[upload_tmp_dir] = /home/xtvcz/tmp
php_admin_value[session.save_path] = /home/xtvcz/tmp
php_admin_value[open_basedir] = /home/xtvcz/hddarchiv:/home/xtvcz/web/xtv.cz/public_html//public:/home/xtvcz/web/xtv.cz/public_html/:/home/xtvcz/web/xtv.cz/public_html/:/home/xtvcz/web/xtv.cz/private:/home/xtvcz/web/xtv.cz/public_shtml:/home/xtvcz/tmp:/var/www/html:/etc/phpmyadmin:/var/lib/phpmyadmin:/etc/phppgadmin:/etc/roundcube:/var/lib/roundcube:/tmp:/bin:/usr/bin:/usr/local/bin:/usr/share:/opt
env[TMP] = /home/xtvcz/tmp
env[TMPDIR] = /home/xtvcz/tmp
env[TEMP] = /home/xtvcz/tmp
Should this work ok?
It does not work only on one domain xtv.cz
, the other one dev.xtv.cz
which uses the same configuration works.
UPDATE:
The initial problem was in the open_basedir configuration.
@eris solution worked. Thank you!
My last reply had another issue, after sudo apt upgrade, php7.4-memcached
was not installed and the site silently failed without giving any error. Unrelated to this thread.
Thanks again @eris have a great day!
Closing.
system
closed
March 28, 2021, 9:13am
#9
