Opencart Multistore with Multi Domain
I am using VestaCP will move over to HestiaCP
Had trouble in the past when setting up opencart multistore using 3 domains, had to make custom changes outside VestaCP.
In HestiaCP is this issue solved?
I will be using nginx with php-fpm in Ubuntu.
You can use Aliases and it should probably work. You might need make some changes how ever never tried
