Hi, I just tried installing Opencart using Hestia “Quick install app”
When install finishes and I try going to the main page I get web error of too many redirect. I see in the address bar http://my domain.com/install/install/install(about 12 times)/index.php.
I’m using php7.4 and the latest hestiacp.
I wanted to use the quick install to make it easier on me but I’m not exactly sure what’s going on. I could just remove the install and do it manually. But I thought if it’s happening to me it must be to others also.
Thanks.
Maybe opencart is configured to redirect to the http version and hestiaCP is redirecting to the https version and you get an infinite loop
It should be patched allready
Yes, it was already patched. But still does the looping.
Using Cloudflare?
Yes but it isn’t set to proxy. Straight IP. I have 4 different sites and none use proxy from Cloudflare.
I found the issue. There was an .htaccess file. I’m not sure where it came from. This was a brand new domain. I created the domain and immediately installed the package.
