Hi guys,
How can I optimize websites in wordpress on hestia?
To explain me better, are there any best practices to consider on the server side only for wordpress use?
Many thanks in advance
Hi guys,
Sorry, I found these articles online
In your opinion, is that enough or is there something else? Thanks
Hello Chris, I faced your problem some time ago.
Although I don’t know if I got the best solution, I am going to share my thoughts.
For compatibility with plugins consider installing nginx + apache + fpm otherwise you will be fine only with nginx and fpm
I tried apache mod pagespeed and the results were not fully satisfying so unless you want to spend +30 hours tweaking you will be better off not using it.
What I have tried is the theme neve by theme isle.
And the plugin perfmatters.
With both correctly implemented I have a pagespeed insights score of 98 in mobile without CDN or cache
Thank you very much Guerrero, I’ll do some tests on it
