2020-12-09 13:32:44 TLS error on connection from send.ida-marketing.com [77.32.206.211] (recv): The TLS connection was non-properly terminated.
2020-12-09 13:32:44 TLS error on connection from send.ida-marketing.com [77.32.206.211] (send): The specified session has been invalidated for some reason.
My SSL for mail.domain.lt is valid Let’s encrypt. So it must be configuration issue, where system does not provide correct Cert when outlook is trying to check it.
this matters its been problem for many years if you google it.
i am not sure the best solution
but now, after i installing hestia the next step is setup and smtp relay
email thingy’s been pain in the head for me past several days…hahaha…
Yeah, i found some having same problem, i always try to solve my problems first.
After renewing certs and messing with everything i decided to write there, thinking theres something specific with the hestiacp.
as i mention I am not sure that i have the best solution.
for me at this moment just setup smtp relay is the best solution
hope its fit to you too.
free smtp relay:
sendinblue - can upto 300 email perday with 40 email per hour
mailjet - up to 200 email perday, for paid also quite cheap for 30K email per month choose the basic price fit for newsletter
