I’m trying to setup a php-fpm status page (fpm-status) so I would need to change a setting in the php-fpm pool file.
First I tried to update the 2 files in the /etc/php/7.4/fpm/pool.d directory: both domain.tld.conf and www.conf.
Then reading some posts in your forum, I tried to create 2 custom templates in the /usr/local/hestia/data/templates/web/php-fpm/ directory: default.tpl and PHP-7_4.tpl that I copied into custom_default.tpl and custom_PHP-7_4.tpl
Trying to open the url domain.tld/fpm-status a “not found” error keeps showing up…
Can you confirm which is the right way to override php-fpm settings in HestiaCP?
The instructions you are mentioning, only indicates PHP-X_Y.tpl file… that means that we don’t need to copy default.tpl as well?
What’s the meaning of “YOURNAME” in the YOURNAME-PHP-X_Y.tpl? is it the username under which runs the website? or is it the domain name used for the website?
