Does anyone have experience with OwnCloud installed on Hestia? I am seeing the following error messages and would like how best to address them as it seems to be with core configuration of PHP and file access. It also feels a big sluggish on a 32GB VPS. I think the “memcache” issue is the biggest problem.
Security & setup warnings
Transactional file locking should be configured to use memory-based locking, not the default slow database-based locking. See the documentation for more information.
We recommend to enable system cron as any other cron method has possible performance and reliability implications.
Some files have not passed the integrity check. Further information on how to resolve this issue can be found in our documentation. ([List of invalid files…]
/dev/urandom is not readable by PHP which is highly discouraged for security reasons. Further information can be found in our documentation.
The “Strict-Transport-Security” HTTP header is not configured to at least “15552000” seconds. For enhanced security we recommend enabling HSTS as described in our [security tips]
No memory cache has been configured. To enhance your performance please configure a memcache if available. Further information can be found in our documentation.
Please double check the installation guides , and check for any errors or warnings in the [log]
When having an open_basedir configured within your php.ini file, make sure to include /dev/urandom .
Feel free to modify it your self but use templates instead…
Currently set to 15768000 according to me its more then 15552000 by 2,5 days. Please enable the systems…
Install php-memcached or php-redis…
I don’t see any issues… How ever some TLC is required…
Thanks for the reply. Are saying you have no errors displaying? It works for me too, just I don’t feel that I should have so many errors. It does not feel optimised. It’s quite slow.(server is 32GB RAM, 4x CPU, SSD)
nicely specs that you have there, perhaps you also need to check the network latency beside the installation or the specs
just suggestion, maybe can help you out
