Package cleaning up after remove Bind9
I find out I dont need Bind9 DNS server, so I dettached from HestiaCP.
Then APT UPGRADE prompt me some packages were not needed. But I am not sure if these were really only used for Bind9
bind9-utils (I think this can remove)
libcares2
node-busboy
node-cjs-module-lexer
node-undici
node-xtend
The only package related to bind9 is bind9-utils and you can remove it. The other ones are not related to bind9 but you should remove them too apt autoremove
o, coz i am not too long with Linux. So you know these were not some core thing that some other thing rely on? (given I only have docker installed beside HestiaCP on server)
libcares2
node-busboy
node-undici
node-xtend
Those packages are not used by Hestia or by any software managed through Hestia. You may have installed something and later uninstalled it, leaving those packages behind. In any case, if those packages appear as removable, it’s because their “parent” package is no longer installed.
