v-update-sys-hestia-git hestiacp main install
This command is returning such an error. Can you remember? I would be very happy if you could help
ERROR: “dpkg: error processing package hestia (–install):
dependency problems - leaving unconfigured
hestia”
potap
May 14, 2022, 2:09pm
2
sudo /usr/local/hestia/bin/v-update-sys-hestia-git hestiacp 1.5.14
Thanks, the panel has been updated but my main problem has not been solved
the panel cannot be accessed. domen.uz:8083/login
I typed the login password correctly but did not enter the panel anyway. Can you help?
potap:
I didn’t know why phpmyadmin didn’t work either
Error during session start; please check your PHP and/or webserver log file and configure your PHP installation properly. Also ensure that cookies are enabled in your browser.
session_write_close(): write failed: No space left on device (28)
session_write_close(): Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php/sessions)
potap
May 14, 2022, 3:09pm
6
sudo /usr/local/hestia/bin/v-change-user-password USER [PASSWORD]
eris
May 14, 2022, 3:24pm
7
Check your disk usage it is out of “space”
du
eris
May 14, 2022, 3:26pm
8
We have added a new package to hestia due to breaking changes in Ubuntu Jammy
You need to install package idn2 …
system
Closed
June 13, 2022, 3:27pm
9
