Password does not match the minimum requirements
Hello
I would need the user to be able to set whatever password he wants at HestiaCP, there is a specific setting that disables the option of “Password does not match the minimum requirements.” ?
Thank you !
Are you trying to get your server hacked?
Because that is how you get your server hacked!
Hi.
I will add strong passwords but i will use more friendly passwords to write by hand VS copy & paste.
Thank you
Please help ?
I would need the user to be able to set whatever password he wants at HestiaCP, there is a specific setting that disables the option of “Password does not match the minimum requirements. ” ?
