Dear guys,
I need to activate PCNTL support for each PHP version installed by Multi-PHP.
Some advice about how to do this?
Regards,
Carlos
Dear guys,
Regards,
Carlos
Never installed or used pcntl, but sounds you need to compile it, at least based to this thread here: https://stackoverflow.com/questions/33036773/how-to-enable-pcntl-in-php-while-using-a-framework-like-symfony2/43157513
This should also work with hestia, let us know if it did.
Dear ScIT
I added support for PCNTL successfully, using the default Apache2 Web Template !
FYI the PCNTL module is used by apps like Mailwizz to send many email campaigns at the same time (parallel processing)
