done with ```
sudo phpenmod -v 8.3 sqlsrv pdo_sqlsrv
But still could not find driver error
done with ```
I restarted php-fpm for PHP 8.3 and now another error:
SQLSTATE[IMSSP]: This extension requires the Microsoft ODBC Driver for SQL Server to communicate with SQL Server. Access the following URL to download the ODBC Driver for SQL Server for x64: System requirements - PHP drivers for SQL Server | Microsoft Learn (Connection:
Does anyone have any idea how to fix this? I would be very grateful for advice or help
I think i need to install this extensions for working with Microsoft SQL Server Version 17.
((( i hate this mssql oh my god
If you read the instructions, in the link Iāve posted, in Step 2, you will see a link to install Microsoft ODBC Driver for SQL Server
Unfortunately it doesnāt work for me.
Building dependency tree⦠Done
Reading state information⦠Done
E: Unable to locate package msodbcsql17
I did it.
Now how do I install sqlsrv and odbc so php starts seeing them?
Yep. For Debian 12, and all commands below
But now iām getting an error SQLSTATE[IMSSP]: This extension requires the Microsoft ODBC Driver for SQL Server to communicate with SQL Server. Access the following URL to download the ODBC Driver for SQL Server for x64: System requirements - PHP drivers for SQL Server | Microsoft Learn (Connection: in my laravel app
If you followed all the instructions and it doesnāt work Iām afraid I canāt help. But, are you sure you installed all you need?
php -m | grep -E 'odbc|sqls'
Also, did you restart php 8.3?
systemctl restart php8.3-fpm
root@host:~# systemctl restart php8.3-fpm
root@host:~#
root@host:~#
root@host:~#
root@host:~#
root@host:~# php -m | grep -E āodbc|sqlsā
odbc
pdo_sqlsrv
sqlsrv
root@host:~#
Now im getting an new error
SQLSTATE[08001]: [Microsoft][ODBC Driver 17 for SQL Server]SSL Provider: [error:0A00014D:SSL routines::legacy sigalg disallowed or unsupported]
Well, the extensions are installed, the problem seems the SSL communication between your Laravel app and the MSSQL Server, one of them doesnāt like the signature algorithm used. I donāt know if it is because you must use the last ODBC Driver version (18 instead of 17) or you must use any older version.
Yeah. Iām need to use 17 version cuz the mssql itself version 12.
So me need to change /etc/openssl.conf looks like
Guys! Can you tell me please is that possible to downgrade to odbc 13?
