Hi guys, I am using Debian 12 and just installed HestiaCP.
How to install pdo_odbc and pdo_sqlsrv for php 8.3 to send queries to mssql from Laravel application?
Thanks for you time! I really appreciate
apt install php8.3-odbc php8.3-sqlsrv
root@host:~# apt install php8.3-odbc php8.3-sqlsrv
Reading package lists⦠Done
Building dependency tree⦠Done
Reading state information⦠Done
E: Unable to locate package php8.3-sqlsrv
E: Couldnāt find any package by glob āphp8.3-sqlsrvā
root@host:~#
root@host:~#
root@host:~#
To install sqlsrv you should follow the instructions on this page (Steps 2 and 3):
Note: Iāve never installed them nor will try to do it.
sudo: pecl: command not found
You must install php-pear
root@host:~# sudo pecl install sqlsrv
WARNING: channel āpecl.php.netā has updated its protocols, use āpecl channel-update pecl.php.netā to update
downloading sqlsrv-5.12.0.tgz ā¦
Starting to download sqlsrv-5.12.0.tgz (193,767 bytes)
ā¦done: 193,767 bytes
34 source files, building
running: phpize
sh: 1: phpize: not found
ERROR: `phpizeā failed
Change php8.2-dev by the php version you are using.
sudo apt install php-pear gcc make autoconf libc-dev pkg-config libreadline-dev php8.2-dev
sudo pecl channel-update pecl.php.net
anyway
running: phpize
As I said above:
This is solved using:
This is solved installing the dev package for the php version you are using on your system.
Anyway
running: phpize
Also for some reason in the Hestia settings I canāt make 8.3 php primary. In general settings ā server. 8.2 is displayed last, although I have 8.3 as well
But are you installing the php dev package for your default php version?
php -v
PHP 8.2.22 (cli) (built: Aug 2 2024 16:01:44) (NTS)
But i am using 8.3 for my Laravel app
use php8.3 instead
sed -i '/^\t"php-8.2",/a \\t"php-8.3",' /usr/local/hestia/web/edit/server/index.php
v-change-sys-php 8.3
root@host:~# sed -i ā/^\t"php-8.2",/a \t"php-8.3",ā /usr/local/hestia/web/edit/server/index.php
root@host:~# v-change-sys-php 8.3
update-alternatives: using /usr/bin/php8.3 to provide /usr/bin/php (php) in manual mode
root@host:~#
running: phpize
root@host:~# php -v
PHP 8.3.10 (cli) (built: Aug 2 2024 16:00:00) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.3.10, Copyright (c) Zend Technologies
with Zend OPcache v8.3.10, Copyright (c), by Zend Technologies
root@host:~#
The last commands configured php 8.3 as your default version,
Did you install php8.3-dev ?
sudo apt install php-pear gcc make autoconf libc-dev pkg-config libreadline-dev php8.3-dev
Thank your sir.
Guys, can you tell me what is the correct path if iām not use apache2?
Iām talking about this:
printf ā; priority=20\nextension=sqlsrv.so\nā > /etc/php/8.1/mods-available/sqlsrv.ini
printf ā; priority=30\nextension=pdo_sqlsrv.so\nā > /etc/php/8.1/mods-available/pdo_sqlsrv.ini
just /etc/php?
