Am trying to change the document root for all domains so that it is:
/home/{{user}}/web/{{domain}}/app/webroot
Instead of:
/home/{{user}}/web/{{domain}}/public_html
I hope someone on here can help.
Instead of:
Create a new template with the new docroot
@Eris, I did what you suggested yesterday in one of my other posts. The problem am having now is with the Proxy Template. I created /usr/local/hestia/data/templates/web/nginx/cake.tpl
But when trying to save I get this error message. Error: nginx restart failed
Am not sure what is wrong now.
Check nginx -t in command line after the template is activated…
I did that just now and it says this:
nginx: [emerg] “proxy_cache” zone “{{domain}}” is unknown in /etc/nginx/nginx.conf:161
nginx: configuration file /etc/nginx/nginx.conf test failed
I then checked the conf file seems fine as therere is brace (}) there.
I assume you are using caching template as basis?
Also copy the .sh file and give it the same name as the template name
Ok,
Let me understand this correctly.
I copied
/usr/local/hestia/data/templates/web/nginx/default.tpl
Into
and made my changes there but I did not know I had to copy caching.sh into cake.sh too.
Is that what I need to do?
I changed and caching.sh into cake.sh too and it works.
Thanks.
