Persona server for Hestia
Hi there.
Is it possible to use Percona server instead of MariaDB for Hestia?
Thanks.
Short answer: no, it’s not supported.
A bit not that short: If you can implement it yourself, you can maybe switch to it - we’re open source which means, that you also can make changes to the system.
Thank you for the detailed explanation.
