I must have done something stupid and I need some advice. I installed a new server and imported the old backups. Unfortunately I didn’t install pgsql and I had a pgsql database in my backup, but I don’t need that. Now my backups are not working as there is a problem when I try to backup pgsql. Is there any way to remove the pgsql database from the profile?
Option 1:
Extract the tar file and import everything manually
Option 2:
Remove hestiacp/v-restore-user at 221487e1a0f5e9052630ca3739d8aaae8abb6ea7 · hestiacp/hestiacp · GitHub
Those lines and try to again
When done importing remove the database config in /usr/local/hestia/data/users/user/db.conf
