PHP 7.4.5 how to upgrade?
I added new repo:
apt install apt-transport-https lsb-release
wget -O /etc/apt/trusted.gpg.d/php.gpg https://packages.sury.org/php/apt.gpg
sh -c 'echo "deb https://packages.sury.org/php/ $(lsb_release -sc) main" > /etc/apt/sources.list.d/php.list'
Installed PHP:
apt install php7.4
but only CLI was updated. How to set up new PHP on default?
Probaly you missed this part here:
You will find it under Server -> Configure -> Web Server
Checkout the release notes, in special this part here
  • Apache, Nginx + ApacheMultiphp will not be enabled automaticaly since internal mod_php module will be disabled and might cause isues with some apps when switching to php-fpm backend.To enable multiphp run the migration script: $HESTIA/install/upgrade/manual/migrate_apache.sh
Source: https://docs.hestiacp.com/release_notes/1.1.0.html#new-multiphp-system
Без названия
