I’ve changed the value of max_input_vars = 5000 using the control panel and checked all versions php.ini using nano in console
but WordPress says it has 1000 value instead of 5000
I tried to change Max input time to see if it will change in WordPress and it did
I also tried adding the value using htaccess, and wp-config but it didn’t worked
I tested two websites and both of them shows the same max_input_vars = 1000 instead of 5000
Any idea why max_input_vars not changing?
