I have been struggling to get the webmail part of my server to work. I do have a working Nextcloud server. But regarding the webmail part of the server, I keep getting the 500 error that says
Oops… something went wrong!
For administrators: Please check the application and/or server error logs for more information.
Checking /var/log/roundcube/errors.log I see the following:
[15-Nov-2022 11:03:26 America/New_York] PHP Warning: Uninitialized string offset 0 in /var/lib/roundcube/program/lib/Roundcube/rcube_utils.php on line 1308
[15-Nov-2022 11:12:09 America/New_York] PHP Warning: Uninitialized string offset 0 in /var/lib/roundcube/program/lib/Roundcube/rcube_utils.php on line 1308
Looking at line 1308 on the “rcube_utils.php” file, I see the following block of code
@msreddy Are you saying that you also get this message when you open roundcube (webmail.domain.you):
then you can check this given below solution it’s work for me:
