Looking for the php-fpm logs but I cannot find them. Are they disabled by default?
If you mean the error logs for php when you access a website try /var/log/{web server}/domain/domain.error.log
General logs are found in /var/log/ folder
I mean the error log where php-fpm would throw server reached max_children.
My /var/log/php7.4-fpm.log is empty and I’m not sure if the /var/log/{web server}/domain/domain.error.log is what I’m looking for
Any suggestions?
[email protected]:/var/log# cat php7.4-fpm.log
[email protected]:/var/log# cat php7.4-fpm.log.1
[23-Jan-2022 00:00:09] NOTICE: error log file re-opened
[23-Jan-2022 17:06:29] NOTICE: [pool xxx] child 23632 exited with code 0 after 10971.389447 seconds from start
[23-Jan-2022 17:06:29] NOTICE: [pool xxx] child 11135 started
[23-Jan-2022 17:06:35] NOTICE: [pool xxx] child 23618 exited with code 0 after 11001.150048 seconds from start
Seems to be working fine
I found those files and like yours my /var/log/php7.4-fpm.log file is empty and the other one php7.4-fpm.log.1 has some lines dating since hestiacp was installed.
Is this normal no logs since?
