PHP FPM pool configuration
Hello, hope you are well,
I want to ask to those who have experience with php-fpm if I am thinking well the following 2 cases to configure a pool in php-fpm:
First scenario: to configure a pool for a particular site (“site_1.com” belonging to user “user1”) I follow these steps:
  1. In the directory “/etc/php/X.X/fpm/fpm/pool.d/” I create a file with the name “site_1.com.conf” (if I understood well how Hestia works, the file name must be the domain name and not an arbitrary name right?)
    And inside the file:
[site_1.com]
listen = /run/php/phpX.X-fpm-site_1.com.sock
listen.owner = www-data
listen.group = www-data
user = user1
group = user1
pm = ondemand
pm.max_children =
etc
etc
  1. I have been looking at the Hestia bash files and if I understand correctly, Hestia will populate the “fastcgi_pass” parameter with the correct value “unix:/run/php/php7.3-fpm-site_1.com.sock;” in the nginx template without the need to do it manually, correct?
Second scenario: if I want to configure or change the default pool values for all sites on a server it is only necessary to edit “www.conf” (in “/etc/php/X.X/fpm/pool.d/”) and then just do a restart of php fpm, correct? or is it necessary to make some other changes somewhere else?
Thanks in advance for any corrections !
No create a custom template:
And make sure it is named:
YOURNAME-PHP-8_1.tpl
Where 8_1 is the php version
Then change the template in Edit Web domain
Only if you make the changes to the template and not make the file your self they will get overwritten as explained in any template…
Yes this is the only way… Make sure there can only 1 exists …
Thank you Eris !
