Wayne
1
Hi there,
Got everything set up on the server, DB and Web files copied over, config file checks out.
If I go to mydomain.com/offline.html page works fine
If I go to mydomain.com/index.php page does not work.
Everything is installed as needed, I believe? Excuse my lack of knowledge here, the is something I am doing for the first time.
Any advice?
index.html has priority over index.php did you remove the index.html file?
Wayne
3
Nope, no files moved or changed so far. Site was copied from a different server that was written in PHP.
eris
4
Check /var/log/apache2/domain/domain.error.log or /var/log/nginx/domains/domain.error.log
And check the contents
