I know PHP proc_open was in disable function by default, but I enable it and function is available to me. But when I try to run node /htmltopdf.js file which use puppeteer to make PDF file I am getting Permission denied function.
I run the command directly on server Shell and it works fine, so I know command is working,
Now my best guess is SELinux like stuff or some safety feature is avoid it. I am no expert in server so I don’t want to disable any security feature without knowing it.
Can someone please guide me where I should look and for what process/setting
But did you enabled it in both php (fpm and cli)? because I suppose node is using cli. Also, double check the php version used by node, because maybe you enabled proc_open for fpm version 8.3 but node is using php cli default version that is 8.2.
I enable for FPM as I run this in Web browser only using Symphony’ Process library, and if proc_open is not available the library show the same. (that is how I know it is disable) … and proc_open is failing so it is surely executing.
So, it is just that php is in some safe mode or it is not loading the node path.
It is enable in both… still same error, and yes I have version 8.3 in command line as well as for web. and PHP info reflect the same (i.e. proc_open is not in disable list) … as I said the function is working otherwise PHP say ‘function not found’ not permission denied to execute command.
Okay, I figure it out. the Node command I was running was in /root folder. and PHP doesn’t have access outside of web root. Even php -v command won’t run.
so I copy the node binaries in accessible path and use the full path to command. it all works now. I secure my binary using htaccess and stuff so I guess I am good for now
