Hi.
Today I updated HestiaCP from v1.5.15 to v1.6.10, using apt upgrade.
During the upgrade, errors occurred with the PHPMailer and FileManager packages.
Now I don’t have access to FileManager, Roundcube or PHPMyAdmin.
In the administration panel, I have two alerts:
Composer installation failed!
PHPMailer will not work without Composer.
Please try running the installer manually from a shell session:
v-add-sys-phpmailer
And
The File Manager will not work without Composer.
v-add-sys-filemanager
When i run v-add-sys-phpmailer
PHP Fatal error: Allowed memory size of 2097152 bytes exhausted (tried to allocate 692224 bytes) in /tmp/tmp.MywfcsXs9o on line 1375 Error: Composer install failed
Running v-add-sys-filemanager
PHP Fatal error: Allowed memory size of 2097152 bytes exhausted (tried to allocate 692224 bytes) in /tmp/tmp.6bv4h8vgXJ on line 1375 Error: Composer install failed
I have been reading possible solutions in the forum, but so far none have worked for me.
Here is the upgrade log.
Hestia Control Panel Software Update Log
OPERATING SYSTEM: Debian (11)
CURRENT VERSION: 1.5.15
NEW VERSION: 1.6.10
RELEASE BRANCH: release
BUILD TYPE: Production release
INSTALLER OPTIONS:
Send email notification on upgrade complete: true
Send installed log output to admin email: false
[ * ] Backing up existing templates and configuration files...
[ ! ] Performing system health check before proceeding with installation...
[ ! ] Adding missing variable to hestia.conf: API_SYSTEM ('0')
[ ! ] Duplicated keys found repair config
[ * ] Health check complete. Starting upgrade from 1.5.15 to 1.6.10...
[ - ] Now applying patches and updates for version v1.6.0...
[ * ] Update exim4 config to support rate limits
[ * ] Add support for optional rejecting spam
[ * ] Enabling SMTP relay support...
[ * ] Enable Samassassin Cronjob
[ * ] Updating nginx configuration with changes to Cloudflare IP addresses
[ * ] Update phpMyAdmin server configuration
[ - ] Now applying patches and updates for version v1.6.1...
[ * ] Fixed an issue with rate limits and alias mail addresses
[ * ] Fixed an issue reject spam not working properly.
[ - ] Now applying patches and updates for version v1.6.10...
[ - ] Now applying patches and updates for version v1.6.2...
[ - ] Now applying patches and updates for version v1.6.3...
[ * ] Fix an issue with sending large attachments to Google / Gmail
[ - ] Now applying patches and updates for version v1.6.4...
[ - ] Now applying patches and updates for version v1.6.5...
[ - ] Now applying patches and updates for version v1.6.6...
[ - ] Now applying patches and updates for version v1.6.7...
[ - ] Now applying patches and updates for version v1.6.8...
[ * ] Create config roundcube logrotate file
[ - ] Now applying patches and updates for version v1.6.9...
[ ! ] Upgrading File Manager to version 7.8.2...
[ ! ] Upgrading Roundcube to version 1.6.0...
[ ! ] Upgrading PHPmailer to version 6.6.5...
[ * ] Upgrading phpMyAdmin to version 5.2.0...
Installation tasks complete, performing clean-up...
[ * ] Rebuilding user accounts and domains, this may take a few minutes...
- admin...
- sysadmin...
[ * ] Restarting services...
Error: ERROR: Restart of hestia failed.
UPGRADE COMPLETE.
Could you guide me how to fix the errors?
Thanks in advance
