PHPMailer not found while updating HestiaCP
While updating Hestiacp 1.9.3 to 1.9.4 on Debian 12 I got the message
PHP Fatal error: Uncaught Error: Class “PHPMailer\PHPMailer\PHPMailer” not found in /usr/local/hestia/web/inc/main.php:456
Stack trace:
#0 /usr/local/hestia/web/inc/mail-wrapper.php(39): send_email()
#1 {main}
thrown in /usr/local/hestia/web/inc/main.php on line 456
This error was shown twice when it was suppose to send the two emails after upgrading, one confirming the upgrade and the other with the upgrade log
I searched for the folder PHPMailer on this server and on other servers and can’t find PHPMailer on any HestiaCP server with 1.9.3 or 1.9.4 versions
Once the folder PHPMailer does not exist on HestiaCP how was it suppose to use its class to send the emails?
It should be here /usr/local/hestia/web/inc/vendor/phpmailer/phpmailer
If you don’t have it, execute this command:
v-add-sys-dependencies
Thank you for the information.
I was not finding the folder because I searched for PHPMailer but is phpmailer
The folder exists and contains all the files, sizes and permissions as other HestiaCP web servers I have
What could be de cause for the upgrade script not being able to find the class?
I don’t know. But is it working fine now?
I requested a backup creation and got the email confirming it was done, however this error was on the process of apt upgrade so I am not sure if there is an issue with the upgrade script and I am not sure if the emails sent by the control panel use PHPMailer.
Is the PHPMailer used to send the control panel emails?
Yes, it is.
In that case it should be all good
Yes, seems so.
Thanks again!
