I try to upload SQL database using PhpMyAdmin, each time I get this error.
The database files size is 130Mb
504 Gateway Timeout
The gateway did not receive a timely response from the upstream server or application.
Can you help me fix it?
Does hestiacp have an option for remote SQL login?
This is what I do: I have a regular user with ssh access to a temporary folder that I use to drop in files (or out)
After I move my files, I start a new ssh session and then I visit that folder and perform the mysqldump operation or restore a WordPress…
system
closed
#4
