I was looking at the Apache error.log and found this errors
[Tue Sep 08 11:23:52.932017 2020] [proxy_fcgi:error] [pid 1018937:tid 139953027663616] [client 51.211.193.159:0] AH01071: Got error ‘PHP message: phpmyadmin: Failed to load /var/lib/phpmyadmin/config.inc.php Check group www-data has read access and open_basedir restrictions.’, referer: https://MY.SERVER.IP.ADDRESS:PORT/list/db/
I found many IP addresses from different countries that I don’t recognize. Most of them showing the message above and others are showing the following messages.
Thanks for posting this question and your last post to say that you found the solution. Can you provide the steps for how you changed the default login URL. I am new to HestiaCP (just migrated from VestaCP yesterday) and I was just checking the logs to see how things are going.
I have a fresh install of HestiaCP and I am seeing these same errors (PHPmyadmin failed to load config.inc.php due to open_basedir restrictions).
These are popping up in the /var/log/apache2/domains/srv01.mainsitename.com.error.log for the Hestia control panel site. It happens whenever I log into and launch phpmyadmin, not some annoying bot.
How did you fix the issue? Also, since this is a fresh install, it seems this should be addressed in the installation process. Is it because the URL is not configured properly and that’s why the warning is happening. @ScIT , is this something that could be addressed during the installation to avoid this. I’m not sure if its a bug, issue in configuration, or something that should just be left alone.
