I am new to hestiacp and I am trying to use it.
I try to import and mysql_db_backup.zip with 1.8 MiB and the phpmyadmin returns this error code:
504 Gateway Timeout “The gateway did not receive a timely response from the upstream server or application”
How can I solve this error?
Thanks in advance
eris
May 17, 2021, 6:49pm
#2
Increase the timeouts between Nginx + Apache2
ScIT
May 17, 2021, 6:52pm
#3
or use the cli command to restore the sql file :).
Hummm, Thanks I increased to 60s the parameter “pm.process_idle_timeout” in file "/etc/php/7.4/fpm/pool.d/www.conf " and I restart the services apache2 and nginx but the error remains.
eris
May 17, 2021, 7:05pm
#5
It worked perfectly, thank you very much Eris
Thanks SciT, the problem has already been fixed.
The command line is by far sadly the best method.
As for the phpmyadmin 504 error. Hit reload once or twice. Sometimes it finishes the task.
ScIT
May 17, 2021, 7:40pm
#10
I would not call it sadly, its the most direct and professional one :).
Hi ScIT ,
For the next database that I have to import in sql.zip format, could you tell me the command to do it. Thanks
Taken from my company’s internal manuals.
I suppose you want to migrate a wordpress.
Dependencies: WP CLI
Login as root
Install WP CLI with this one-line command
curl -O https://raw.githubusercontent.com/wp-cli/builds/gh-pages/phar/wp-cli.phar && chmod +x wp-cli.phar && sudo mv wp-cli.phar /usr/local/bin/wp && wp cli update
Optional: Enable wp rewrite flush command
echo "apache_modules:" >> ~/.wp-cli/config.yml
echo " - mod_rewrite" >> ~/.wp-cli/config.yml
Create web space
Create a new user, domain (cliente.com ) and install wordpress via the HestiaCP interface
Enable BASH access for that user.
We copy the database and wp-config.zip to the public_html folder
With WinSCP or the file manager, rsync, scp or we download it via wget…
SSH login with the unprivileged user that you just created for the domain
Change to the target directory
cd web/cliente.com/public_html
Unzip wp content zipfile
unzip -qqo wp_content.zip
Optional: Destroy and restore database
Destroy wordpress database (for the default install)
wp db drop
Create a new wordpress database with the info provided in wp-config.php
wp db create
Import Database
If the database is compressed:
unzip -qqo cliente.com_db_20210502.sql.zip
We import the database with this command:
wp db import cliente.com_db_20210502.sql
If it fails, or if it is NOT WORDPRESS you may try this command : mysqldump -u mysql_user -p database < file.sql
mysqldump -u cliente.com_82925 -p cliente.com_82925 < cliente.com_db_20210502.sql
Tweaks
wp search-replace http:// https://
Please dont forget the “//” or you may transform https into httpss and break the urls.
Permalink refresh
wp rewrite flush --hard
system
closed
June 16, 2021, 8:06pm
#13
